Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 Doesn't Charge Or Turn On
Hi everyone. I have an iphone 5 that wouldn't charge. Hard resetting didn't work. It just wouldn't power on or charge. The phone is approximately 3 months old. I can't go to Apple because I went before and they told me that the phone looks like it have been tampered with so the warranty is void. To my knowledge, Apple techs were the only individuals to go inside the phone. They said that a coaxial wire was broken. I finally looked inside last night and saw that the interconnect cables were broken, but to my knowledge the interconnect cables have nothing to with the device receiving power. Different lightning connectors have been tested, so it doesn't seem to be a lightning connector issue. I have tried putting it into the comp and the adapter and on both accounts, no avail. It must be a hardware problem. Could anyone please give me insight as to what components are responsible for delivering power to the phone? Does anyone have a knowledge as to where the inductors are located? May Jesus bless you and thank you for your time.
Score 4
Add a comment
Chosen Solution
I sold it guys. It looks like it was water damaged.
2 Comments:
Hey where did you sell it? Seems like I have the same problem with mines.
by
Some guy on craigslist.
by
Add a comment
Most Helpful Answer
If you haven't done this as yet, try holding the Sleep/Wake button and the Home button both at the same time for around 15 seconds.
Score 3
3 Comments:
I tried a soft/hard reset already. Thanks for your reply.
by
I have the same problem, i cant seem to do anything with it like uploading the Itunes, my phone is completely dead, wont charge, Tried hard reset, still no success, driving me crazy love my Iphone :)
Can anyone help, dont think i qualify for a replacement cos the warranty has run out, not happy :(
by
thanks a million it worked
by
Add a comment
Open your phone and take out the battery . Use at least five volts of power to kick the battery for about 2 minutes. Connect the positive to the the first terminal( the contact near the dock) and the negative to the third terminal or the last which is the ground . Connect back and power on, it's should indicate low battery. You should now be able to charge.
Score 2
3 Comments:
I tried it and no avail. The battery seems to be receiving charge but my charger seems to be outputting an insufficient amount of voltage so this process might take longer.
by
how do u kick start your battery with? maybe a silly question, im desp :(
by
This worked for me! I used an old 5v adapter from a previous phone and cut off the connector. Hold the red (+) wire to the first connector and the black (-) wire to the third connector. After 2 minutes I had a battery symbol and the phone started charging when connected to the computer.
by
Add a comment
might need a new lightning port charger. also, try removing the battery and then connecting it to itunes. if itunes recognizes it, it's not the port charger.
www.liljohnnyappleseed.com
Score 1
Add a comment
Please - Check your serial number here to see if it qualifies for the Battery Replacement Program:
https://ssl.apple.com/support/iphone5-ba...
Score 1
Add a comment
Can we Oder a battery of iphone 5 ?
Score 1
1 Comment:
yes, there is battery for iphone 5 available on http://www.laimarket.com
by
Add a comment
Add your answer
JJS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 25,613
