Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
How can I fix a blank LCD screen?
Changed the screen and the LCD has stopped working, I've tried a different screen but I'm still getting the same issue. The touchscreen works as you can still switch the phone off and on, if you hold down the home button the voice control activates. Is it the LCD connector that's the problem and how can I fix it.
Thanks, S2
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Look and see have you damaged any pins were the LCD connector plugs in on the motherboard
Add a comment
Add your answer
S2i will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 350
