Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
Is this aerosol electrical cleaner safe to use on iPhone logic board?
The battery life of my iphone 4 has become terrible after fixing screen, my thoughts are that I must have touched a connection and left grease on it as battery life is good in airplane mode.
I bought this today, is that okay to spray directly onto connections then remove with a swab?
Also, what connections do you suggest I clean?
Thanks!!!
Link to picture of spray: http://i.imgur.com/2X1enye.jpg?1
Comments:
Without knowing the ingredients its hard to say. Some of these sprays have toluene which can damage plastics, some have oil which can cause odd problems. What I do is use a hand pump sprayer which I load with 90% isopropyl alcohol. Then I know what I'm using, and I don't use it for anything else.
by
Add a comment
1 Answer
Chosen Solution
Ben, anytime you use any of those sprays you are running the risk of creating a short circuit with it. I would suggest that you clean the board with a high grade (90%+) of isopropyl alcohol.
Score 2
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,455
