Water damage , Battery connector
Hello People!
First of all , great website! Been searching for an answer but most of the times the topics are a little different then mine ...so i thought ill start a new one!
I got a Iphone4 , it was dropped in the water and i cleaned it carefully with alcohol and it turned on. The problem is , i got a "connect to Itunes" logo on the phone and when i try to restore it comes up with different errors. ( 21 , 2001 , 2006 or this device is not legitable... ).
I opened the device again and checked every component and found out that 1 capacitor was missing. There are 4 capacitors next to the battery connector and 1 is missing because of the water damage . I tried to solder a bypass but inmediately the 2nd capacitor fell off the motherboard.
If you check the picture you will see that there are 3 capacitors. On my Iphone the capacitor with the lower 2 yellow lines is also missing.....
EDIT : Dont know if the picture is viscible but here is another link :
http://www.iphonebacklight.com/wp-conten...
What can i do to fix it? Can i do a other bypass? The power does not end at that capacitor ...right?
thank you for your help , if you need more pictures let me know! :)
Btw , Phone is not charging or turn on without power in usb/outlet.
by Moreno
If your components are falling off, you will have to replace those. If you post an image of your board, we can help you finding out what they are. Use this guide Adding images to an existing answer to add the images. If I interpret your image right, there are 2 capacitors and 2 coils at that location.
Once you replace those, also replace the battery.
by oldturkey03
