Fix Your Stuff
Right to Repair
Store
Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
3038 Questions View all
not signal, suspect ceramic IC chiped
I have a phone my co-worker that was working on and he screwed something up. i suspect this to be the issue?
phone cant get a signal. phone using CDMA network.
Add a comment
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 Answer
Chosen Solution
qpunk, that is reference designator U1001_RF and it is a FPF1039 − Low On-Resistance, Slew-Rate-Controlled Load Switch. The datasheet for that is available right here. It is part of the Baseband PMU. Hope this helps, good luck.
Score 1
Comments:
Thank you vary much oldturkey your the best!
by
you are welcome, and thank you for accepting my answer.
by
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 488
