Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
1035 Questions View all
My friends laptop won't boot up...
For atheros PCIE Ethernet controller v2.0.2.6(09/28/10)
PXE EAO network boot canceled by keystroke
PXE MOF : Exiting Intel PXE ROM
no bootable device - insert boot disk and press any key
client mac addr: b8 70 f4 41 od
pxe - e53 ; no boot filename received
here is a screenshot:
http://i271.photobucket.com/albums/jj145...
Score 2
Add a comment
Chosen Solution
paulo, it is possible that it is trying to boot from the network because it can not find the OS on the hard drive. This could be caused by a bad MBR or a bad hard drive. Check to see if you can access the BIOS, change it to boot from optical drive and use a bootable OS disk. I use a copy of Puppy Linux or Hirens Boot CD. If you can, check the hard drive and see if it is still accessible. If so, copy all your files that you may need to an external drive. after that reinstall your OS. Make sure that you have the proper OS disk as well as access to the drivers for your computer. If you can not access your drive, you will have to replace it and reinstall your OS. Hope this helps, good luck.
Score 1
Add a comment
Hit the cpu twice, it worked.
Add a comment
Add your answer
paulo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 1,378
