1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
163 Questions View all
Why is battery capacity not replaced?
Hello,
I just followed your guide to replace the battery. After looking in the system report I saw that the loading cycles are reset but not the capacity. Its still the number from the old battery. After charging until 100 % in charge remaining there was the same number as in full charge capacity. When taking out the magSafe the percentage immediately jumped down to 85 %.
I tried SMC reset already.
What can I do to see 4680 mAh written in in "Full Charge Capacity"?
Thanks in advance..
Comments:
I also change my battery in my Iphone 4, and I have the same issu about the new one, nothing change and when I connect the iphone for the first charge it show the percentage as the old one.
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Download and run Coconut Battery to see if you get the same information: http://www.coconut-flavour.com
Score 1
Comments:
I did. Same stuff. I start to believe that the battery might be junk :(
by
Add a comment
Add your answer
Dominik Schroeck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 296
