Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3171 Questions View all
Dropped my iPhone, digitizer replaced but still not working?
Hi everyone
I dropped my iPhone 5 and the LCD / Digitizer both got broken.
I replaced them with a new part from eBay and the LCD works and all functions on the phone work (that I can see) but the digitizer does not recognize touch.
I have tested the digitizer on another iPhone 5 and it works perfectly.
I restored the iPhone and it still will not work.
Does anyone have any ideas? I assume it is hardware damage? The digitizer connector on the logic board looks fine and I cannot see any other problems. The phone has also never been water damaged.
Thanks, Ryan.
Comments:
Hi I have the iphone-5s - two different companies have replaced screen and digitizer - neither company could solve the problem - after replacement display works but it will not allow you to input the passcode - ie it doesnt recognise the finger touch ... any ideas
thanks Gray
by
Servis destroy your home button touchID reader - since is unicate for each phone , replacement does not read fingerprints and there is no way to repair
by
I have similar problem. My iPhone was water damaged, and after that everything works, but touchscreen isn't responsive.
Does anyone knows what can cause this?
Znas li ti Milose?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The Tech Genie, check on here step 18 will show you the location.
Orange = Texas Instruments 27C245I touch screen SoC
Yellow = Broadcom BCM5976 touchscreen controller
Rather than a single touchscreen controller, Apple went with a multi-chip solution to handle the larger screen size." Hope this helps, good luck.
Score 1
Add a comment
Look very closely at the pin connections on the logic board sound like the one that plugs into the digitiser got damaged
Comments:
Thanks for the suggestion. I checked the connection on the board and it looked perfect to the eye, even under a magnifying glass.
Is there a certain part of the board that deals with the digitizer on the iPhone 5?
by
Have You ever found the solution for this issue?
Kind regards.
by
Add a comment
I'm having the same problem. Been trying to fix this 5c since forever. I've got the screen replaced, got it check out, iphone Techs. couldn't fix it. I'm more thane sure our problem would be solved if we all bought new logic boards, but they are crazy expensive.
Add a comment
Add your answer
The Tech Genie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 11,348
