The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
51 Questions View all
detects only 3G signal but doesn't read 2G signal
My N8 which I got it from Canada with Rogers network, worked well for an year. Then suddenly from one morning onwards it doen't receive or detect 2G signal.
It works and detects only in 3G signal area. All the tips and tricks had been followed but no use. I took it nokia care and even they couldn't fix it and the reason they said was that I am using it in India but not in canada. So, they couldn't fix it.
Score -1
Add a comment
1 Answer
1st clean the antenna conector, if not working replace the bottom cover assy because there is the pads for the antenna, if still not working you need to jumper the internal antennas and for that you gonna need someone with technical knowledge...
Add a comment
Add your answer
madivada sriramanuja will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 525
