Repair guides and support for cars and trucks by Dodge.
423 Questions View all
High Beams don't work, low beams do on 2000 Dodge Ram 1500?
The brights no longer work but the low beams do. I have checked fuses, replaced one of the bulbs, and tried out a new switch. What should I check next?
Score 1
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Andrew Hindman , check the relays in the fuse box next to the battery. It should be the "Quad" relay
The arrow shows the fuses for the headlights, but you said they are okay, so that leaves the relay, or a short/loose connector in the harness. Hope this helps, good luck.
Add a comment
Add your answer
Andrew Hindman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 81
All Time: 1,901
