Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
57 Questions View all
My Ipad can't on and restore.
Hi, Recently I having this problem where my Ipad 2 can't be on. It keep stuck at the apple logo. So I thought it must the apple logo loop. So i try it with the tiny umbrelle to kick the device out of the recovery mode after I had set it to DFU mode. But it still can't work. So I have no choice but to decided to lost all the data inside my IPad 2 with restoring using the ITUNEs. However it still the same. The Itunes even show up some error code. Can anyone help me? Thanks.
what was the iTunes error code?
Add a comment
Chosen Solution
Have you tried restoring it on a Mac ? Resrore process is more advanced on Macs.
Then, you could bring it back to a genius bar !
Score 1
Add a comment
I had suffered the same problem before. I would suggest you check out the hardware issues. Maybe you can try to restore your iPad while connected it to Mac, and also confirm your security software and settings are allowing communication between your device and update servers. The solution will be a little different in the different iTunes error code (common errors: 1, 10-47, 1002, 1011, 1012, 1014, 1000-1020). If this is useless for you, you might need to try the FORecovery iOS system recovery tool for help. Maybe you can get more details in the fix iPad/iPhone stuck on Apple logo article.
Add a comment
Add your answer
Sam Chong will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 389
