Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Where can I get a replacement wi-fi EMI shield long screw?
Hey all,
I recently brought a iPhone that was in pieces from my friend, I put it back together but I get very poor wifi signal. After looking at it I conclude that this is caused by a missing 4.8mm screw at the top of the iPhone in the EMI shield. I was wondering if anyone knew where I can buy a replacement screw, or if there is another quick fix.
Thanks in advance,
Ryan
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You can get a whole 47 pc screw set on ebay for only 2 bucks.
The screw you are looking for will be there.
http://www.ebay.com/itm/47-Piece-Full-Sc...
8
Also make sure the silver metal spring on the wi fi antenna cover that the screw goes into is still there and didn't fall off.
Add a comment
Add your answer
Ryan vadera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 494
