Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Antenna broken, no service or somethin else?
I replaced the home button, yada yada.
After I did it I no longer received signal. I did notice on the speaker where the signal cord is, I broke the prongs. Is that was the issue is? Do I need to replace it or is it something else?
Score -1
Add a comment
1 Answer
Chosen Solution
There could be several reasons. I would start by taking the whole thing apart again, cleaning all connections with 99% alcohol and reassembling. If that doesn't work then maybe do a network settings reset. and if that still doesn't help, then go with replacing the antennae/loudspeaker assembly. Hope that helps!
Add a comment
Add your answer
Coty Carothers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 191
