Line of laptop computers aimed at the small business market, designed to replace the Dimension line of laptop computers.
132 Questions View all
Can I get some tips to avoid frequent bluescreen problem?
I'm getting blue screen problem in my Vostro 1400 laptop very frequently. I have changed the SATA operation and checked. I extended my RAM too. Can you please guide me how to avoid it.
Score 1
Add a comment
1 Answer
Chosen Solution
Blue screen crashes are OS kernel failures. Yes, often they have a hardware issue like a HD drive thats going or a bad RAM chip (module).
Have you tried running any HD or memory diagnostics? I would first make a full backup of your HD before proceeding. Did something show up?
If nothing showed up - Do you have the system recovery CD/DVD the system came with and/or the OS & App installer disks or image files. If you do I would reformat the HD and install a fresh copy of the OS and install from the original sources (CD or download) your applications, don't forget to update both (OS & Apps) with any needed patches.
If you did get an error you'll need to address what hardware failed.
Score 2
Add a comment
Add your answer
avinash will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 235
