Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
571 Questions View all
DVD REWRITER I have just bought.
Will a HL-DATA GA11N Apple super multi dvd rewriter SATA 678-0576B I just bought be compatible with my iMac Intel EMC No 2133?
Thanks...
Add a comment
1 Answer
Chosen Solution
no unfortunately not. The GA11N is a SATA drive, whereas your 2007 iMac still uses a PATA connection. (iMacs from 2009 and later use the SATA connection)
You want a 12.5mm PATA drive with a 32mm feeding depth (because of the extra depth created by the aluminium bezel)
Here are a few models that will work, but there are 2 versions of each. one has a 22mm feeding depth and the other is 32mm. It doesn't seem like a huge difference, but you will need to use something to push the disk in if you get the 22mm version, as it doesn't grab the disk until its passed the aluminium frame...
Panasonic UJ-875
Pioneer DVR-K05
Pioneer DVR-506PD
Sony AD-5630A
Sony AD-7640A
Also, you will need to check what drive you currently have fitted, as each brand of drive uses a different optical bezel that clips to the outside of the drive, so if you change manufacturer you will need to change bezels too (you can alter the bezels to make them work on different manufacturers, but its much more straight forward to replace them)
Score 1
Add a comment
Add your answer
ricardocoll will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 98
