The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
193 Questions View all
Where is "Memory Heatsink" placed?
I cant find where the sensor 4 "Memory Heatsink" are placed on a mac G5 / late 2004 / 2,5 GHZ.
WHERE CAN I FIND SOFTWHARE 4 CALIBRATE THE SENSOR, its showing 20 DEGR TO HIGH temperature.
IF SENSOR Is ON some cind of cabel, mabee it has been placed wrong, under the warmer part, near the processor.
FAN NOISE - IS THE COMMON REASON 4 ASK.
Score -1
Add a comment
1 Answer
Chosen Solution
You need to find a copy of the AHT for your computer to calibrate it and restore the fans to normal speed. I am including the link from Apple for the PowerMac G5. From this link you can download the manual which should answer your questions about the sensors. Good luck from a fellow G5 owner, Ralph
http://www.apple.com/support/powermac/
Score 1
3 Comments:
What is "AHT" - I am swedish - so i dont understand what its mean.? If you know where to find the sensor - is it any chanse that the answere could be put in this chat?
Thanks 4 the answere, anyway.
by
AHT - U mean Apple Hardware Test = problem - I dont have the original CD. And I cant find any AHT for G5 to download (apple have it for some other models),
But I have Sotfware "Hardware Monitor" - and through that i can see where the problem is = Memory Heatsink = showing to high temperature.
I NEED to know - where to find the "Memory Heatsink Sensor" - where is it placed ? Is it directly on motherboard, or is it throug som cable? If so, perhaps some one before me has moved it to wrong (warmer) place ?
by
From what I can tell the sensor is built in to the heatsink/processor package. This package can't be opened without destroying the processor. If you have not done so please download the manual as it gives a great deal of info (text and photos) to help you maintain the system. Ralph
by
Add a comment
Add your answer
Goran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,742
