The iMac G5, powered by the PowerPC G5 processor, was originally released in 2004.
586 Questions View all
repair or replace my nvidia geoforce 7300gt card in my 24" iMac
how do I either repair a graphics card for my i-mac
2006 24" i-mac
graphics card is the nvidia geoforce 7300gt
mac had a lot of problems with this card
can I either buy it used somewhere or have it repaired
Comments:
How did you determine it to be the video card, not bad capacitors? Did you connect it to an external monitor - if so was there no video?
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
I think machead3 is a bit confused by the ranges you've mentioned. the title says its a 24" iMac with a GeForce 7300 GT graphics chip, whereas the range selected was the iMac G5, which is completely different, and have very different common problems.
The iMac G5 is the one that has capacitor issues, and can create a graphics fault, were as the 24" range had problems with both its power supply, and its graphics chip. can you confirm the symptoms you are having with the machine? as if it is video related, it could still be the the logic board, LVDS cable or the LCD panel...
But with regards to your graphics card, there is 1 of 2 solutions available. you can either re-flow the board, which is a fairly complicated procedure and will not be a great long term solution, or you can purchase a replacement card, but they are very difficult to come by, as that range has been classed as vintage for a while now.
sorry, neither is a great solution, i know.
Score 1
Add a comment
Add your answer
bobby taylor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 485
