Why is my PowerBook blinking a black question mark and smily face?
hey when i turn on my
PowerBook G4 Titanium DVI Model A1001
it shows me a white screen for 2 minutes then shows me a black question mark and a white and blue smily face what do i do?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Your machine can't find a valid operating system. This can be caused by a corrupted system folder or a failed hard drive. Boot from the original system CD holding down the "C" key and start to install a system, the second screen the pull down menu appears. Go to Utilities. Open "Disk Utility" and see if you can repair the drive. If you can see the drive and disk utilities doesn't fix it then try installing a new system. If you can't see the drive then you probably need to replace it.
Score 1
Comments:
i have the same problem but i dont have the original system disc. is there way to this this with out the disc?
by
Add a comment
Add your answer
luis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 159
