Why is my laptop screen white?
My laptop screen stays white when I turn it on.
Sounds like a hard drive failure. See if it will boot from the system installation disk and see if the hard drive can be repaired.
If you have tried connecting an external monitor but still the same then its seems like a drive or operating system failure. However you can perform system restore by following steps:
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 8,106
1 Comment
have you tried an external monitor yet?
by oldturkey03
