Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
297 Questions View all
Logicboard to LCD output problem?
MacBook Pro 15" A1286 Late 2009
Long story short:
-Initial problem: build-in LCD wasn't able to render black, instead flashing green was appearing.
-First Diagnosis: external monitor worked fine. Went to apple store / genius bar, they run their diagnosis and they only detected a battery problem (it has 400 cycles ish / nearly 4 years old) and a RAM problem (I upgraded by a non OEM apple RAM). But nothing with the logic board. Thus we concluded that it has to be the LCD.
-First attempt to solve the problem: I bought a new LCD and replaced it. But the problem still persistent.
Any idea how to solve it:
- Software problem..... ?? I don't think so.
-Logic board problem.....could be, but a new logic board is too expensive. Suggestions?
Thank you very much
Pol
Comments:
what are the last three digits of your serial number? This will help us to properly identify your MacBook Pro
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
I'd say it's probably a problem with the cable.
http://se.eetgroup.com/i/MSPA2830-Apple-...
It's worth a shot!
Edit:
Since its working fine with an external monitor, there shouldn't be any problem with the chips. So, either LCD or the LVDS-Cable, and it's not the LCD....
Good luck!
Comments:
The cable look fine from the outside, but it may be a bit dodgy inside. Is this happening often. I mean problems with the cables. ????
Thank you very much.
by
In my experience, it's more often the cable than the LCD.
by
Add a comment
Add your answer
Pol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 158
