2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Cleaning up a sticky power key after liquid spill
I spilt coke on my laptop about a couple months ago, and it did not do a lot of damage as far as I'm concerned.
As it happened, I used a tissue to suck the coke, and then power off my Mac.
I put my Mac there for a day, and then turn it on (I know I should've waited longer just for sure), it works perfectly. Nothing weird, just one problem, the power key is sometimes sticky.
I'm looking for ways to clean that key, I know opening up the whole MacBook is a way to go, but is there anything else I should try? Is it possible to take just one key out like what I've done with a Apple Wireless Keyboard?
Score 1
Add a comment
1 Answer
Chosen Solution
Apple's current unibody design across the laptop models has a serviceability flaw unlike past models. Most have there keyboard riveted to the top case assembly so it can't be removed or disassembled to clean. You can pop off the key caps and try cleaning underneath if you can catch the spill quickly (which in your case you didn't).
Generally you need to deal with the chemistry of what you spilled and the repercussions of leaving it Vs cleaning it up. Even a small spill with the wrong drink can be costly if it gets into the inner-workings of your system! Hopefully you didn't spill too much in and you can clean up whats left without replacing the top case assembly.
In your case you have an acidic & sugary drink Coke so you need to neutralize the acid and remove the sugar stickiness.
The best cleaner here is distilled water {not tap water!!} it will dissolve the sugar and with luck dilute any remaining acid so it doesn't corrode things over time. But, there is a downside using water as it to can cause damage if you use to much or let it sit. To dry out the water you'll need to use a good quality Isopropyl alcohol after you have removed as much water as you can first.
First you'll need to disconnect your systems battery (follow the iFixIt guide) before doing anything! Try using a cotton swab (Q-Tip) moistened with distilled water around the power button. Using a paper towel blot up the water and repeat with a fresh swab and paper towel. Once you feel you have cleaned up all of the Coke do the same thing again this time with the Isopropyl alcohol.
Let your system dry a few days, reconnect your battery and you should be OK - Good Luck!
Score 2
4 Comments:
Yes, but I am more concerned about how to get the cap out, will that be safe to just brute force? I've taken out one from my Apple Wireless Keyboard, and the plastic thing holding the cap in place seems quite fragile.
by
The power button is not the same as the keyboard keys it can't be popped off unlike the keyboard keys Key Cap can. Sorry ;-{ Use the swab around the button as I outlined. Here's a link to a company that offers key caps and they have a vid on YouTube on how to correctly pop the different caps of the keys. TheBookYard
by
Thanks for the link, it really helps a lot. FYI, Retina MacBook's power button is a key on the keyboard replacing the eject button since it doesn't have an optical drive.
by
Your right! I had the non-retina model stuck in my head - Opps! Still use the Swab to wet down and soak up the coke don't twist it use a bloating motion so the cotton doesn't snag on the mech. Good Luck!
by
Add a comment
Add your answer
shanehsu will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 11,082
