Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Glue or not glue? iPhone 4 glass
I have a glass and LCD from iphone 4,
My question is, Glue or not glue? LCD on glass.
Score 1
Comments:
I was thinking of just gluing the corners, if broken again is more ease to repair.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
The glass and LCD are fused together. I don't think that it's glue, but I could be wrong.
If you read Replacement iPhone 4 Display Assembly Parts it should clarify some things.
Score 2
Add a comment
yes glued, you can use a transparent uv glue. not so easy!!!
Add a comment
a cheap and simple way is to glue the back of the LCD or use a two sided tape. Then glue or use two sided tape on the glass, above and bellow the LCD area.
Add a comment
Add your answer
nobatente will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 204
