Why does the top screen of my DS Bleed(Run)?
Whenever I move the top screen while playing, the image on the top screen runs, But i can manage to play if the screen is set at its normal open position. any movement on the unit causes the colors to begin running. I would like to know the cause of this; and if possible if the problem is fixable. I'd like to make my DS in as good condition as possible so I can give it to a family member.
2 Comments
Sounds like a bad cable. any chance you can post an image of the "running colors"?
by oldturkey03
Righto, so I went and took some pictures of it. Apologies for the darkness but it was the only way to make the screen not look blue.
DS 1
DS 2
DS 3
DS 4
Hope this helps!
Edit: The screen is bent only slightly, if at all.
by Sedorael
