Repair guides and support for vehicles manufactured by Hyundai Motor Company.
68 Questions View all
What are ohm readings for 2001 Hyundai Santa Fe coil pack testing?
2001 santa fe Hyundai 2.4 ltr. 5spd manual transmission
Add a comment
1 Answer
Chosen Solution
luana, try this :-)" 1. Measurement of the primary coil resistance. Connect the negative (-) terminal of a 3V power supply to terminal 2 of the power transistor; then check whether there is continuity between terminal 3 and terminal 2 when terminal 1 and the positive (+) terminal are connected and disconnected.
Replace the power transistor if there is malfunction
1. Measurement of the secondary coil resistance.
Measure the resistance between the high-voltage terminals of the ignition coil.
Standard Value:
20+/- 15%(Kohm)
Hope this helps, good luck.
Score 1
Add a comment
Add your answer
luana will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,559
