PC doesn't completely power on
It started happening this morning, when I turned on the PC, it powered on and turned off, then again and again. It went on for a while and then I turned off the PC. It did the same thing when I turned it on again, more quickly. I made a video to show you it, now the led of the power on button almost doesn't turn on.
You should hear the noise of the PC that powers on and off too.
The video:
https://docs.google.com/file/d/0B6hlY2Qy...
Thank you for the help!!!
UPDATE
Here the images of the open PSU
6 Comments
have you checked your CPU fan as well as your PSU? the noise could be a fan or the hard drive. Need to either see or hear more to make sure....
by oldturkey03
Yes, It's the fan that makes the noise. I spotted a lot of dirt too, could be that the problem???
The hard disk as well as the others drives are ok.
I tried to make another video but there is too noise around. I'll try again later.
by Giovanni
Which fan is it? The PSU fan or the CPU fan?
by oldturkey03
Ok, both the fans are dirty, the noise comes from the PSU. I can't see inside the PSU, should I open it and make a photo? (without touching anything obviusly).
by Giovanni
It does sound and look like a bad PSU. Photos may help and do not touch anything inside the PSU. The capacitors will hold a charge for a good while, and touching those may be a "shocking" experience. What make and model is your PC.
by oldturkey03
Show 1 more comment
