Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2983 Questions View all
4S reboots automatically after shutdown (not while plugged to pc)
Hello everybody!
I have a 4s 32gb with this problem: when I turn it off (holding on-off and sliding on "turn off"), it reboots itself immediately after.
The problem doesn't occur when the iPhone is connected to the pc. Why?
I've already tried to replace the battery, but the problem persists. I've also tried to reinitialize in DFU mode, withouts results. Do you know what it can be? Battery connector, charging connector, on-off button....?
Thanks
Teo
ITALY
Score 1
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
open you iPhone and test it. unplug the power cable first. turn off device and check. if its still reboots, unplug the dock connector and check again....
have a nice repair
iPhone 4S Dock Connector Replacement
Comments:
Sorry iwillfix, what do you mean with "test it"?
I have to:
1 - unplug the cable
2 - turn off the device and check if it reboots again
Those 2 points I've already done.
Then you said to unplug the dock connector and re-check again in the same way?
Sorry for my english, I'm italian =)
by
so did the device still booted up by itself when the power button cable was disconnected? yes? cable ok.
now do the same thing with the dock connector.
turn off phone, open and disconnect dock connector cable, turn device on and back off again to look if it boots by itself
btw your english pretty good ;-p
by
Ok, I've disconnected the dock connector: after shutting down the device it doesn't reboot itself.
I only hope that it's a problem on the dock connector and not on the "mobo"...yyyyyap! XP
by
replace the dock connector and you will be fine :-)
by
DONE! Thx a lot, iwillfix! ;-)
This is a great website!
by
Show 1 more comment
Add a comment
My 4S did the same thing. I took it Apple and was told to buy a new phone. Another post on this site suggested cleaning the docking connector with isopropyl alcohol. I carefully did it with a tooth brush and IT FIXED IT!!!
THANKS
Comments:
The toothbrush solution don't work for me.
I open the phone and disconnect the battery connector and wait for a couple of minutes and after connect and turn phone on.
No more sound and reboot problem on my 4s...for now...
by
Add a comment
i have the same problem, nothing suggested online worked.
my phone worked fine before i upgradet to IOS7.x.x which sugests the problem is a software bug, and not hardware related ( unless the hardware got faulty during the software upgrade, which is dobtfull )
I think apple put this issue on the code on pourpose to force people to buy iphone 5's
Add a comment
I shut down using the two bottoms at the same time.
Add a comment
Nuno, same thing happened to me right after the update AND my battery runs low faster than it used to...
Add a comment
Add your answer
Teo will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 53
All Time: 9,863
