Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
External Enclosure for MacBook Optical Drive?
I'm taking apart my old mid 07 macbook and was hoping to use the optical drive externally for my macbook air. I tried getting an enclosure ( http://eshop.macsales.com/item/Other%20W... ) however the ports on the enclosure and the optical drive are different. I was wondering if there is either an adapter or another enclosure that would be able to connect to the optical drive?
Score -1
Add a comment
Chosen Solution
Mike Tucker, "Be sure to determine which model Macbook you have when installing new parts because earlier models have a PATA/IDE connection to the motherboard rather than SATA." I just checked the manual and cross-referenced the drives and it looks like yours is a PATA connection. There is not enough information on the link you posted but it looks like its for 2010 and up, so most likely SATA. Hope this helps, good luck.
Score 1
Add a comment
Most Helpful Answer
A self-powered USB hub may be the answer to your port problem. You'd lose portability but I wouldn't think most people would require an optical drive on the road (or foot as the case may be). External power is advised because the single port can't power something like an optical drive, and/or you may need to use a printer or some other USB device as the same time as your optical drive.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
1 Comment:
Sorry, I think I should've been clearer. The port in the external enclosure and the port on the optical drive don't match.
by
Add a comment
Add your answer
Mike Tucker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 99
