Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
559 Questions View all
The iMac doesn't recognize the Macintosh HD, what can I do/replace?
Three months ago, I bought Mac OS X Snow Leopard, and since that time, each time I turned the computer on, a sparkling question mark appeared.
As it is said in the manual, I re-installed the 10.6 version three times, but I has not changed anything.
Yesterday, I forgot to remove the install CD from the computer and when I decided to turn it on today, the installation program worked.
The problem is that I can remove the CD and, even if I decide to install the version one more time, the Mac doesn't find the disk (Macintosh HD).
I followed the instruction even the ones that uses Terminal, but in the column "Mounted on" there was only "/", contrary to the other disks.
I hope that someone will understand what I'm talking about (I'm french and English is a really vague memory from school) and will help me.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Your machine appears to have shipped with system 10.4.10. Use the original system installation disk to install it first. Then upgrade to 10.6. If your 10.6 disk is gray, it is for another machine and will not work on your machine. Please give us the last three figures of your serial number. Have you changed the hard drive?
Score 1
Add a comment
Add your answer
Henri Nietshaven will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 147
