The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Questions View all
Filling the gas tank without the pump shutting off?
Everytime I go to put gas in my truck, it acts like it is full of gas and the pump shuts off. It takes ten minutes to put a few gallons of gas in my truck.
Score -1
Add a comment
1 Answer
Chosen Solution
Remove the filler neck hose from the fitting where it attaches to the fuel tank. Look inside the opening for the fuel tank, about 3 inches down there will be a mesh screen. Remove the debris from this and you should be good to go after you reassemble everything. Watch out for spiders in here.
Score 1
1 Comment:
+ make sure the vent to the filler neck is not clogged either.
by
Add a comment
Add your answer
tgkavon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 329
