Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
How can I (slide)unlock my iPhone5 without using sleep + home button?
Hello,
If i lock my iPhone 5 i cant slide to unlock because my sleep + home button doesn't react.
If i lock my iPhone the screen gets black and then i cant do nothing because the buttons doesn't react.
I there a way to (slide) unlock the iPhone on a different way?
Please help.
I do not lock(assertive touch) my iPhone now, because i don't have a solution to unlock the iphone again.
Thanks.
Score 3
Add a comment
Most Helpful Answer
You can get Activator from Cydia to use your volume buttons as your home/power button when you press them at the same time.
Score 2
1 Comment:
please share a link of activator
by
Add a comment
Try pluging it in to the charger this should take it out of sleep mode
3 Comments:
I use that already + headphone to activate Siri.
A method without a accessories?
by
No there's no other way unless you get a text or ring the phone!
by
Maybe a option in cyidia?
by
Add a comment
Repairing the home button is a 5 minute job.
3 Comments:
Nice advise. But unfortunately the home + on\off button can't be repaired because there is some important parts broken on the logic board.
That's why this question.
by
Pollytintop, it really is a 5 minute job. It takes 30 seconds to unlock and lift the front panel, one minute to disconnect the front panel from the phone, another 30 seconds to replace the home button switch. You still have 3 minutes to put everything back together.
by
Adem, can you describe what parts are broken?
by
Add a comment
We're on about the iPhone 5 ya no
Add a comment
Go fix the home button...
Add a comment
I have also kind of a same problem. my lock screen button only works for once after like 100s of pressing actions. is there any way to fix it externaly or without disassembling my phone?
Add a comment
Jailbreaking it and using touch to unlock should work
Add a comment
please unlock my apple id IMEI 358827051610974
Add a comment
I also have this problem I have to go to settings and turn off "vibrate when on silent" I can now use the switch above to bolume buttons to light up my screen
1 Comment:
not work(( it switched sound on/off without light up screen
by
Add a comment
Add your answer
appledem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 13,879
