Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
539 Questions View all
MacBook won't boot, no chime, black screen, turns off then back on
So mine is the typical story of coffee spilled on a MBP. Immediately turned off and turned it upside down. I took the battery out and began to allow the parts to dry.
I took it apart and did a minor clean with rubbing alcohol and a q-tip. Got most visible liquid staining/corrosion off all circuit boards. I put it all back together and turned it on. Sure enough it turned on a booted normally, everything seemingly OK. Then after about an hour of being on it would randomly shut off with no warning. After holding the power button for a while it would finally come back on with the grey 'out-of-focus' screen and progress bar. Once that filled it it worked OK until the next random shut off.
So I thought I would more deeply clean the parts on the logic board and replace the keyboard and MagSafe circuit. I did this and went over most of the logic board with 99% rubbing alcohol. After all was dry and ready, I re-assembled it.
Now when I press the power button the light on the front comes on, HD spins up and fans turn on. After about 5 seconds it completely shuts off (HD clicks off) as if the power button was held down. Then by itself, it turns back on (fans spinning, HD spinning) but the screen remains black and nothing happens. It will sit like this forever with no action.
Did I somehow cause more damage to the logic board causing it to not turn on at all now?
I have re-seated the RAM, tried it with no RAM etc it does the same thing every time. Seemingly failing POST early on.
Any suggestions would b appreciated. Thanks
Comments:
Now I have it running but it will only stay on for a short time (~10min) which leads me to think that it is something to do with the heatsink and/or heat sensor. Suggestions?
by
Add a comment
1 Answer
Chosen Solution
Your symptom does suggest heat. take look at THESE guides and consider removing the heat sink and applying new thermal compound and also check the fans are working and not clogged with dust.
Comments:
May also be worth running the AHT. Apple Hardware Test is available on the media that came with your computer - refer this LINK for more info
by
Add a comment
Add your answer
dylancramer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,147
