CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
417 Questions View all
Why LCD Won't Turn On After Replacement?
I just replaced an LCD and digitizer on an iPhone 4 Verizon but after putting everything back together, the screen just remains black/off. I've tried reconnecting the LCD and digitizer and the battery. My computer recognizes it when I plug it into iTunes but the screen remains off. Any suggestions?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Reset iPhone, see if better. Restore iPhone, see if better. Try new front assembly.
Add a comment
Try you old screen again and see if you get an image on the screen this will let you no that the screen you installed is a bad
Add a comment
Add your answer
mircoejr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 466
