Repair and support for the controllers that shipped with the PS3. Released mid 2008, the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
109 Questions View all
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
Comments:
How did you clean it? Did you check the components while you cleaned it?
by
How I do ? i already tried to reset the controller and its not working with the USB cable ...
by
all the components are fine they have no breaks or anything
by
yes, I was wondering how you cleaned it.
by
with a scott towel
by
Show 1 more comment
Add a comment
Chosen Solution
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
Score 1
Add a comment
you may need to re sync it to the console.
Add a comment
Add your answer
Nicolas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 782
