The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
82 Questions View all
How do you replace a cracked screen?
How do you replace a cracked screen on a Samsung Galaxy s 4 Phone?
Comments:
S3 or S4 phone? You have selected S4 as device but typed S3.
by
Add a comment
Chosen Solution
S3 Guides
S4 Guides
Check these out
Comments:
Sorry it is S4
by
did you find the guides helpful?
by
Add a comment
You have to remove the battery and heat the screen up to a uniform temperature of 160-180 degrees F. with a heat gun. Using a dental spatula or iopener gently start to lift the glass off of the frame. Never press down always using upward pressure. Be very careful not to scratch the plastic digitizer.Use extremely light pressure when lifting. As the separation starts you will see the loca turn loose from the digitizer. Pay extra attention to the areas around the button so not to tear the flex cables. Clean the old tape off completely and replace with new. Clean glass well and wipe off any dust. Make sure when applying the adhesive tape that the surface is perfectly clean or you will crack the new glass
Add a comment
Add your answer
Pat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,035
