Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
631 Questions View all
How much does HDD Torx compatible?
hello guys.
i saw the replacement HDD of MacBook Pro 13" (after 2011 early) and i wonder how much Torx screw driver compatible.
it says T6 used, but can i use T8?
because before i5, C2D used T8 it says, and also my other stuffs uses T8 so i want to unite my tools.
i think T7 may works, but anybody knows T8 also works?
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
You need to use the correct sized Torx driver for the given screw.
Score 1
Add a comment
The size of the Torx head is determined by the thread size of the screw - larger thread = larger the Torx driver refer here and here. You cant arbitrarily change the Torx size
Score 1
Add a comment
Add your answer
Anonymous will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
