When Changing the clutch hinges do I need Loctite on the screws?
When I open the MBP, the lcd opens fine, but if its on an angle it just flops all the way back, so I was going to replace the hinges. I just figured the hinges were worn out, so I wanted to know should I put loctite on the screws?
Add a comment
1 Answer
Chosen Solution
Yes - there's an adhesive used in the original assembly - sometimes you can see it on the threads after you remove the screws.
Remember to return and mark accepted the answer that best solves your problem.
Score 1
Comments:
Thank you for your response, I used Loctite Blue 242.
by
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 186
