Repair and disassembly guides for AirPort Extreme routers.
83 Questions View all
Airport Express External Antenna?
I recently bought an Airport Express and shortly thereafter, got the idea to mod it with a bigger antenna. There's really nothing online showing that sort of mod but many with the extreme!
How can I add an external antenna to the Express?
I saw one, I believe it was by Quickertek. Although, it wasn't much cheaper their way than buying the Extreme!
Help, please!
Comments:
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The contemplation of an inny or an outy antenna ;-}
The Airport Express, Airport Extreme or Time Machine where never intended to be a super long distance AP's, others offer these.
The other aspect here is the Express unit is heat welded so you end up making a mess of the case. The Extreme or Time Machine units can at least be opened.
Score 1
Comments:
Thanks Dan,
I already have it opened though, I had already decided to take on this project when I posted the question. And as I said before , I saw one modded with an antenna mounted through the top, If I were to do the same on my own, where would I need to make the connection to the logic board? Would I have to remove the original antennae?
by
I wasn't able to add pics but I may have found the answer, it looks like there is a U.FL post just below both of the 2 antennae. So, a couple of pigtails with SMA connectors at the opposite ends should do the trick, I finally learned about that (U.FL) type of connector just yesterday, a D-link router was being modded!
Thank you!
Shaun
by
Add a comment
Add your answer
Shaun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 54
All Time: 2,792
