How to improve air circulation?
I've got a Early 2011 13" MBP which I use for photo editing. I find that the cooling system is severely lack in the sense than anything more than a basic touch up causes the fan to spin up loudly, while the system pretty much slows to a halt. I'm not talking a heavy editing, just moderate. Something like using the dodge and burn tools in aperture over a small area.
I have replaced the thermal paste, which has done wonders to performance but still isn't best. I wonder if there's a way to increase air circulation. I've noticed that with the MBP retina's, they have vents at their base. I was wondering if those base will fit on the regular MBP. That or is there any other way to improve circulation. Perhaps removing the optical drive completely so that it can pull air in from the side? It's not ideal, but I'm really looking for improvement. I've upgraded to 16GB RAM and SSD in hope of fixing it but it hasn't helped.
Add a comment
1 Answer
Chosen Solution
Laptop "coolers" or "icepacks" could help'' - thats external cooling. Using a fan app to force the fans to come on earlier, run longer, or all the time could help - ''but naturally that will impact battery time. You might be able to add an additional fan in place of the optical drive (run it off that power supply) that's a mod rather than a repair.
Remember to return and mark accepted the answer that best solves your problem.
Score 1
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 13
All Time: 656
