OEM SATA 3 6G cable not good enough for 6G
I recently upgraded to a OWC Mercury Extreme Pro 6G SSD drive. After a clean install of 10.8.3, I found that I would get beach balls all the time. Tried the same install with an Intel Series 520 SSD, same results. After hours of research I found that the OEM cable has issues running at 6G and gets crosstalk from the battery indicator cable that is in the same harness. I was able to alleviate the issue for time being using 2 sheets of Reynolds Wrap to shield the SATA cable.
I want to know if this replacement part sold on ifixit would resolve this issue so I don't have to use the redneck shielding method? Does anybody know if it's shielded well enough to handle the 6G bandwidth and not get interference from the other cable?
MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable
