Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
581 Questions View all
ifixit caddy not working
My ifixit caddy doesnt work in my late 2011 macbook pro 15inch. I tried to install it and I figured i wired it wrong but i didnt because when I put the optical drive back in, it works fine. The SSD isent the problem because i put it in an enclosure and it works fine. Does anyone else have this problem?
Score -1
2 Comments
Did the drive ever work in the caddy? Does it work in the hard drive slot? What is the make and model of the SSD?
by
the drive never has worked in my caddy. it works in the hard drive slot, it is a OCZ SOLID 3 hard drive
by
Add a comment
Chosen Solution
See if your old hard drive will work in the caddy. This is the way you want to set it up anyway. The BUS speed of the optical drive slot is slower than the hard drive slot. The drive is a 6 Gb/s. and your hard drive slot is rated 6 Gb/s.
Score 2
Add a comment
Im having the same problem. Late 2011 15" Macbook Pro neither my new SSD or my stock HDD will work in the caddy, which i just got in the mail on friday. Both drives work in SATA slot and in external case, superdrive works fine after i reinstalled.
Add a comment
Add your answer
chriscraik100 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 415
