2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
413 Questions View all
How can I repair a blackened screen
My Macbook fell to the ground and a small part of the left of it is blackened, how can I fix it ?
Add a comment
Chosen Solution
It sounds like you have cracked your display, and unfortunately, due to the fact that the LCD is integrated into the glass and housing, you will have to replace the whole upper display assembly in order to get the display back to new.
MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement
This is the only way to repair it, because the LCD display is physically broken. THe display can be found here:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Display Assembly
Hope this Helps
Owen
MacBook Pro 15" Retina (Mid 2012-Early 2013) Display Assembly Image
Product
$419.99
Score 2
Add a comment
You have to replace the entire top clamshell assembly
Add a comment
Add your answer
El Kettani Driss will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,510
