Greyed out wifi - BT works
Hi,
I've recently replaced the LCD on my fathers phone after a tin of food was dropped on it. Everything on the phone works but the wifi is greyed out.
I've looked online and the common greyed out wifi also shows issues with bluetooth however this is working fine. I'm assuming it's something to do with a connection somewhere however when I've checked everything it all seems ok.
I could have put the wrong screw in somewhere but I don't know which screw is to go where........it was more of a trial and error when trying to fit the screws. I hope someone can help - I can't respond to any testing straight away as I will not have the phone in my possession however I will be able to get hold of it within 24hrs.
Pete, as for the screws, just take a look at a guide like this one and read the steps on the right side. The screws are properly identified and should make it easier to place the back where they belong. As for your WiFi, any recent upddates to the OS? Have you tried to turn Airplane mode ON, then turn the phone OFF, wait 10 minutes. After that, power up the phone, turn airplane mode OFF? when you replaced the screen, did you make sure that none of the other components looked damaged?
by oldturkey03
