Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Questions View all
left over part (after fix) small cloth
Hi, after replacing the home button I have a small piece of rolled up cloth left over. see both links
https://www.dropbox.com/s/3zs45ivhcixc9k...
https://www.dropbox.com/s/c8hmf6sbept84h...
Is it essential? and how and where do i put it back?
In the tutorials I can see it positioned between the outer shell and the dock connector cable, but nowhere is mentioned that it can come loose, or how to put it back or how to attach it
secondly; is it possible that because of that missing part my screen is litting up dim.
1 Comment
here you can see it clearly located
https://www.dropbox.com/s/9f3xah7gpt6o2d...
but how to get it back, and is it essential?
by
Add a comment
Chosen Solution
It's a grounding cushion. Not a critical part but for the sake of perfect repair, you may want to put it back.
Score 2
2 Comments:
thanks,
Can i just lift of the backside and push it back in on the spot where we can see it on the picture? (as long as it touches the outer shell)
Or do i have to disassemble more parts, and is there another critical part it has to touch?
by
Try to squeeze it in
by
Add a comment
i have never seen this part before i dont think its needed. check you brightness isnt on the low setting. if not then you have blown the backlight
1 Comment:
here you can see it clearly located.
by
Add a comment
Add your answer
julia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 149
