Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
How to properly test for battery life?
I would like to test a battery with multimeter to tell if it's still good or dead. I understand that I should test voltage under load, connected through resistor not through direct connection to multimeter.
What type of resistors (how much Ohm's) should I get for propely testing the iPhone battery?
Score 1
Add a comment
Chosen Solution
You would need a Cadex battery testing device to get a truly accurate reading. Unfortunately, these cost thousands of dollars. Depending on the model you get. There are ones for testing and repairing, speed at which it conducts the tests and how many you can do at a time.
Standard battery testers are too unreliable and incapable of telling you what you need to know. They will usually have BAD FAIR GOOD or EXCELLENT. A new battery will consistently never get an excellent reading and a known bad battery could get fair - good readings.
So I would think removal of the battery to test isn't very economical.
Their are several apps ( I think I use battery doctor for my Note II) but they also have it for iPhone.
If the battery is in a phone now and functional, you could try charging it to 100% , putting the phone in airplane mode and put the brightness down to the lowest possible setting. Change the screen time out setting to stay on till button is pressed and see how long it stays on.
Score 1
Add a comment
Most Helpful Answer
I am not positively sure but try to use the 10,000 ohms because i believe the specs for the iPhones are 1200 to 800... hope it works for you best wishes from me!
Score 1
Add a comment
Add your answer
Georgey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,080
