Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
Help me fix my MacBook? This is a real doozy.
Hello! I am hoping some people here might have some advice on what to do in my long struggle to fix my black Macbook.
I have not been using this machine actively since 2010. In January 2010, I accidentally spilled coffee on the machine. I was able to dry it out recover it etc and restore it to functioning, but problems began, particularly with power. It would occasionally not boot. When it did boot, everything was normal, but it basically grew worse and worse as the year went on, to the point that I basically would not use it as a laptop anymore and would just leave it at home in its particular position to ensure I could use it there. Eventually I stopped all this nonsense and got a new computer but that's a separate story.
About a year later I started trying to experiment with using the machine here and there. I found that it would occasionally boot on, but very rarely. More often than not the screen would flicker (including the iSight light whcih would flash green) but it would not actually turn over and start up the machine. If I held down the power button continually it would occasionally just keep going and going flickering. At this point in time I consulted some folks at the Apple Store who basically said there was nothing to do, the logic board was probably shot and it would be very expensive to replace.
Every now and again I would try using the machine. One day I surmised (from reading similar forum posts here) that a new battery might help. So I got one and it did - for a minute. Maybe once or twice though, it miraculously did power on. and if i left it on, it kept going. But if I slept it, took out the power, etc, who knows if it would come back on.
Then it reached a point where if I tried to use it it would be completely unresponsive. No clicks, no flickers, nothing. Finally I took it to an authorized repair place (I'm based in CT) and they did a diagnostic, told me I had a completely shot logic board and the only thing to do was to replace the board. Which still seemed strange based on my experience but at that point it had not turned on for so long that I figured it was probably done.
That was about 5 months ago. Flash forward to today - I pulled it out of a closet and plugged it in, just to give it a try - and bam! the charger worked, the light came right on, and it actually seemed to come directly out of sleep back to the last desktop I had open on it. Completely and totally bizarre. (I backed up some files that had been lost on a subsequent machine right away, of course).
So now I'm puzzled. What do you think? Is this a complete logic board fail? Something on the board that needs repair? A power supply issue?
If I could restore this machine to be functional and consistent it would be wonderfully helpful and also restore my faith in computing forever!
Many thanks for any advice!
Comments:
Also in case you are wondering:
2.4ghz Core 2 Duo
2gb ram
by
Hi again all, does anyone have any more advice on how I should proceed?
by
Add a comment
Chosen Solution
Plug it into an external keyboard and see how that works. Also boot up from your original system installation disk while holdi9ng down the "D" key and run diagnostics on it. Let us know your results.
Score 1
Comments:
I ran diagnostics which reported "No trouble found."
What do you mean plugging into an external keyboard?
by
Add a comment
Mayer will be more versed in this than me but I am thinking the video card is on the fritz. I had some problems like this and it was the video card. If it is apart of the logic board then you may be out of luck!
Comments:
Out of luck because it would be irreparable if that's the case?
by
I believe so. I do not see where you can replace the Video card. You can however replace the logic board which is that case will have your vid card embedded on it.
by
How do you suggest trying to figure it out? take out and inspect the board?
by
Hi twbranch, do you have any advice for how to determine if the video card is the problem?
by
Add a comment
Add your answer
HughBerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 169
