CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Won't Boot up or Show up in iTunes?
So the other day my iPhone turned off. I tried the "Hard reset" to turn it on, but the home button is buggy, and it won't work. I tried iTunes, but it doesn't show up. I don't know what to do. The Apple "Genius" Techs. say it's really dead, but I want to know if I can repair this, and how I would do that.
Comments:
the very first thing you should fix is the home button, the battery and double check the dock connector as well.
by
Add a comment
Chosen Solution
P K, the very first thing you should fix is the home button, the battery and double check the dock connector as well.
Score 2
Add a comment
Try replacing the battery, but if that doesn't work, you probably have a defective logic board.
Add a comment
Add your answer
P K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 179
