Non-Unibody, Core Duo & Core 2 Duo Processors
456 Questions View all
Stuck on screen with Blinking file sign a question mark in it.?
when i turn it on all it does is show a screen with a file on it that has a question mark in it. Dont think its the drivers because there is no clicking noise. sounds like its booting up but just stays on that screen.
Add a comment
Chosen Solution
Felicia Haze, the ? over a folder indicates that no valid bootable system was found. This could mean that your HDD has failed, or that your filesystem developed errors. The first thing I would do is to run Disk Utility and attempt to Repair Disk from the DVD that came with your MBP.
Score 3
Comments:
dont have the disk. didnt get one because i bought used. im pretty sure thats what happened i was deleting a file and the power chord came out an it turned off wen i restarted it thats all it would do and all its been doing since. any ideas about what else i could do or where i could get a disk?
by
Hi Felicia, Contact Apple with your computer info and they will sell you a copy of the original OS for about $15, Good luck.
by
Add a comment
Try erasing and reinstalling the OS, but if that doesn't help, the hard drive probably failed.
Comments:
She does not have the disk.
by
Add a comment
Add your answer
Felicia Haze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 320
