Model No. A1367 / 8, 16, 32, or 64 GB capacity
1283 Questions View all
I can't charge my iPod
Hello,
I can't charge my ipod anymore, but I used 3 different chargers so it's a problem with the ipod, what can I do?
Score 1
Comments:
Is it being recognized by iTunes (or your computer) when you plug it in?
by
i have the same problem. my ipod wont charge but I know it is not the ipod's battery . it is the bottom part that I plug it in . how could I fix that?
by
Add a comment
Chosen Solution
matthias, check your dock connector for any bend or broken/corroded pins. Clean it with some isopropyl alcohol and a few puffs of compressed air. If that does not make a difference, you might start by replacing the battery. Here is the guide for it and the battery is available right here as well as many other places. If a new battery wont work, you may have issues with either the dock connector or the PMIC as well as the charging coil itself. Those are not easy fixes....Hope this helps, good luck.
Score 2
Comments:
I have this same problem. Please help.The iPod wont function with the charger but it works fine otherwise.
by
Add a comment
Add a comment
Add your answer
matthias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,125
