Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
4 Comments
We replaced the igniter and it fires but doesn't get as warm as it should. Cycles off too soon. Thinking it may be operating thermostat. Where is it located in Whirlpool gas dryer. Thanks
by Ray
I have a similar problem. Also, my timer won't advance. I had noticed in the past that the buzzing sound that ignites the gas was going on and off before it stopped going on at all. Does that symptom pinpoint the issue, or will I still have to do multiple tests? Thanks!
by mconsidine99
I bought the fuse for the dryer but it still won't get hot, what is my next option?
by Shelia Allen
Did any one fix this problem? Mine is doing the same thing. Lights the first time. After that it doesn't light again. It makes the buzzing sound and the timer also has hung up at times. I did all the continuity checks and they all seem good.
About ready to just go buy a new one.
by lookforjack1
