Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Keyboard and Power Button Won't Respond
Recently, my HDD was corrupted, so I had to resinstall my OS.
However, a new issue arrived, my Keyboard and Power button won't respond at all (though I still have the backlight working on the keys). I can't do an SMC for these obvious reasons (which may fix the issue).
I didn't spill anything on my computer or damage it, etc.. I also checked if the Keyboard ribbon is plugged in (it is). Not sure what I can do to fix the issue.
I didn't spill anything on it (no liquid damage). Some of the keys do respond, though are erratic and don't represent what I'm pressing (space bar may be a 9, or something like that).
Score -1
1 Comment
Just to be clear here: Your OS is loading and you have your desktop showing, correct? Your trackpad and button are working, correct? So you are able to shut the system down using the menu pull down (or you just putting it to sleep).
by
Add a comment
1 Answer
Chosen Solution
Double check the connections on the ribbon cable to the logic board. Ensure the connection is square, and if there's a ribbon connection that the ribbon is "right" side up, slid in all the way and the cam was opened before insertion and locked after.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 269
